hope this is not a repeat of another post
noob here...but I found a problem with the installation manual that comes with the Biostar Tforce6100-939...just want to share with everyone so same mistake is not made
basically, the manual says to place the rams next to each other...however, if you do this, the board will only read the rams as single channel
You need to skip a slot in order for the rams to be detected as dual channel (or just place the rams in the same colored slots)
