Found my problems...
Patriot
[H]ard|DCer of the Month - March 2011/June 2013/De
had some networking woes...
the lower end switches I were using evidently didn't like my cascading setup...
so that took the dual 2.9ghz quads and dual 1.7ghz 12cores off the net..
dual hexacore system got hung as well...
swapped out a switch and ran a direct back to the main lab switch...
rebooted dual hexa...
with the network working I should be adding 3 amd dual hexa and 1 intel single hexa...
if I get round to it... another dual i7 2ghz quad...
EDIT.... IF you are a beta tester... go to folding forums NOW!!!
you will be glowing for awhile...
/tries to peek through the keyhole in the beta testers only door.
sticks finger in keyhole...
just apply...
:p
I don't have the time to fiddle with my boxen most of the time.
It would also require me to poke my nose outside of the [H]ard forum. :eek:
:p
I was not and am not very active at foldingforum...
when i applied I stated that I help the community out from hard...
EDIT.... IF you are a beta tester... go to folding forums NOW!!! you will be glowing for awhile...
LOL, glowing as in afterglow?? Probably PPD related... The only beta testers I'm aware of still folding for this team are Tobit and nitrobase. Neither have been active posting recently, unfortunately.
Wow, all this talk makes me miss Tobit even more........
Yeah, wondering what's up with him. He did take a hiatus last year as well. We all need a break sometime.
client related...
OK, but how could this be so good if it doesn't translate into moar PPD? (just kidding)
On a serious note, looks like PG is still operating in full lock-down mode with their ultra classified ATS access level clearance and need to know ludicrousness. So much for the DAB and greater transparency...
I took a beating from network downtime and 2684s...
I am coming back with a vengeance...
I have sorted out my cpus and have begun doubling up more boxen...
pita... 1u heatsinks and they used different threads... modded the problem away...
I have 168cpu cores folding.... for an average of 10.5 cores per rig...
228 threads average of 14.25 threads per rig...
That should fix my ppd deficiency ...
