Was just killing some time tonight over at the evga forums.
Found this link here:
http://www.evga.com/community/messageboard/topic.asp?TOPIC_ID=18022
Cliff's notes version:
"I have a 1T fix that works for a friend of mine who has the NF41 and some UCCC memory sticks. At his request I made an effort to get his machine working at 1T and i did it!!!!
Using a A64 tweaking program called A64info v0.5 (which can be Googled for and found on the Xtreme Systems forum) I found a few key settings which enabled me to run his UCCC sticks very fast and stable.
-Change DRAM Drive Strength to 'Weak' from 'Normal'
-Change DRAM Data Drive Strength to 'Level 1(reduce 50%)'
-Change Idle Cycle Limit to '256 cycles'
-Change Command Rate to 1T
Others should try this and if it works for everybody with 1T problems, perhaps eVGA could make the necessary items changeable in a new bios!!"
Anyway, for shits and giggles I tried it on my NF-44 and lo and behold I can get 1T working properly. All I can say is woot.
