Forum suggestion
Sovereign
I've seen some other comptuer forums have "Help Me Buy/Build" sections. Is there one here (and I'm blind) or if there isn't, could adding one be considered? I don't know where to put my "$3k Summer Super-computer" comments thread otherwise...
If it's about building your own, I would suggest General Hardware instead of OEM, but yeah...depending on which you're looking to do (build vs buy) I would say that those are the two subforums to use.
OEM if you're looking to buy a pre-built system, General Hardware if you're building your own.
