Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
When gaming, within 5 minutes, the Power Supply fan will speed up it's RPM's greatly. Does anyone know how to disable this? Its much louder than all the fans in my case.
The fan in your PSU is thermally regulated. While gaming, the system is being stressed more, which includes the PSU. This means that the air entering the PSU is warmer, and the PSU itself also needs to dissipate more heat, hence the fan speeds up.
You can either disable this behaviour, which will kill the PSU, and possibly the rest of the system, faster, or you can replace the PSU fan with a more silent one.
