The short version of my problem is I have a new Fortinet 60D that I upgraded to v5.0.7 firmware. I then went through the Wizard to set it up. (sorry, new to Fortinet and it makes it easy to get the initial setup done) However, after rebooting my 60D it was back at defaults. I have tried different ways of going through the wizard and it won't save.
Fortinet support has been terrible so far so I thought I would ask your thoughts. I had the problem one day, spent 1hr + on hold and ended up having customer service just get my number for a call back. Got the call back 24 hrs later and explained my problem. The engineer said he would test that out and get back to me. It's almost been another 24hrs and still have not heard back.
I did figure out that if after running the wizard I backup the config, then restore that backup config it seems to save the settings. However, when I tried putting it into production it was not acting right. My laptop plugged into it could surf the net, ping internet hosts etc just fine. A workstation on the network I was using to test could ping the Fortinet, pull up the admin page but could not surf the net or ping out.
So, I removed the Fortinet from production as it was not acting right. It was setup as Full UTM by default so I don't know if there was some setting there not allowing traffic.
At this point, if I can't get an answer about the wizard, I may just try setting it back to default, and manually configuring everything. Being a newb though that could end up creating a new set of problems.
