It's your 4 hours, do a full format is you want. But doing it to find bad sectors is ludicrous. The OS / hardware is going to find them when your first try to write data to them (which is all a full format does anyway). Besides, that's what backups are for right?
I was just poking around Seagates website earlier today for other reasons and noticed that they listed the return rate for their current drives at .34%.
Now, they ship allot of drives. But, if you want to find out if you are 1 in 300 now, or 6 months from now, help yourself. It's your data. The drive will never fail at the worst possible time, no, that never happens.
Finding a few bad sectors is not the issue. Discovering that you have a useless piece of crap hard drive (like I did) is the issue. Most likely it is good. But.......
How important is your data?
Don
My data is important enough to have current backups of it and not rely on the quality control of a manufacturer shipping out millions of drives a month.
How does formatting discover a useless drive anymore than trying to install your OS or copying your por...err data to it would?
for some reason i don't trust these larger drives, i dont know why.. i had one Seagate 750 go bad on me, then after a check it was fine, then went bad again, ever since then i haven't trusted anything over 500G with data i care about....
I agree.
I guess it would just be nice this day in age with how far technology has come for people to not have to worry so much about backups.home raid arrays...
Shouldn't computing become easier for the home user, it seems more and more our homes are turning into server rooms with 1 system for this, one for that, one for backing up this, one backup for the back up, et cetera!
I like these huge drives primarily for back ups - that's how I'm using my 1.5TB Seagate. I prefer just one huge external drive that I update often rather than spanning across multiple smaller drives. Then for really important data I'll make a second or third backup using older hard drives that I've retired from use.
My point is that it doesn't seem very rational to avoid large drives for your data when you can also have large drives for your backups.
Doing a full format doesn't guarantee a sector never goes bad, or is always writable or readable. If you do a full format, you might find that it's writable now. But six months from now, the same sector might have deteriorated.Now, they ship allot of drives. But, if you want to find out if you are 1 in 300 now, or 6 months from now, help yourself. It's your data. The drive will never fail at the worst possible time, no, that never happens.
Please note that when you format a drive in windows(format), Linux(fdisk), solaris(format) it is doing absolutely nothing to the drives sectors/blocks. All it is doing is adding the file system to the drive which includes the superblock and inodes for drive use.|
If you want to reset the sector/block size, you need a low level format. In todays world you can do this but only on certain drives. On very large drives, the software needed to map to the solution is just way to complex for a home user to do, though it can be done at times. Its just very complex and very long and tedious. All drives are now pre-formatted at the low level by the manufacturer.
Low level formatting used to be required to map the bad sectors on the drive. Sometimes if the drive developed new bad sectors, you could redo the low level format to map around the new bad blocks. It usually meant your drive was on it's last legs, so for most people it was a waste of their time.
Modern drives detect and remap the bad sectors on the fly. There is a set number of spare sectors on your drive. Once the drive starts to fail though, the spare sectors get used up pretty quick. I think their is a SMART parameter or 2 that tracks this info.
Early IDE drives were not low level formattable (is that a word?) in the field, although some manufacturers added that capability to their diagnostic programs. I just considered the drive toast though if it ever got to that level.
Don
LOL!I've heard that you should do a full format on a new drive... and a quick format on a drive you need to reformat that you know has been working.
I got my 1.5tb two days ago, and have formatted it 2 times, failing both times at 73%. come to find out the 680i chipset needed new drivers to support that new drive. after the driver load and another 4.5 hour format, im rocking.
For anyone interested this is the article i found leading me in the right direction
http://seagate.custhelp.com/cgi-bin...F9zZWFyY2hfdGV4dD0xLjV0Yg**&p_li=&p_topview=1
LOL!
Although it takes a long time, run the maintenance option on Spinrite
www.grc.com
I'm laughing at it because it doesn't have any basis in fact. Drives can fail or develop bad sectors at any time.Why LOL at that?
If anyone cares about data, although rather pricey for some of the cheapskates around here, Spinrite will save you many, many hours of frustration and prevent more dollars lost then the cost of the program.
I lvl5 all my new drives with spinrite, and in the last year it has found 2 that have serious errors 'fresh out of the box'. I used to be blind to this type of thing and because HD's are so cheap now just go buy another $80 drive, but by doing that you are only promoting this 'cheap as possible while mostly stable' crap that all the manufacturers are pushing out in the last few years.
<0> What it does is this: typically it'll take a sector of data, read it into RAM, then erase the sector on the drive, then write the data back to the drive and read it to verify it... then do that again, and again, upwards of 15K times per sector, one reason it takes so long
<0> But in the end, you get a drive with sectors that have been refreshed several thousand times over and each one is verified with every rewrite before the next one is worked on
<0> So when SpinRite marks a sector as bad, it truly *is* bad and useless
