formatting ssd need help
newbie22
hi, i have intel 320 120gig SSD which i'm using in G73sw. Now the thing is when i installed OS and files from recovery DVD's it's only showing 87gig WTH?? does anyone knows wha'ts going on, can i reformat this and do it again. Pls help, thx
Thats right because HDD manufacturer's falsely advertise the size of their drives. They base everything on 1000, when really it should be 1024.
Try using CCleaner to clean out some temp files. Delete System Restore points, hibernation and move your Pagefile to a HDD partition if you have one.
thx guys/gals for tips.
ASIA911 how do you delete hibernation and move pagefile, by the way i have original 500gig hdd, i could use that.
