deadman_uk
- Jun 30, 2003
Ive heard people say that formatting your hard drive damages it.... is this true?
Lazy_Moron said:At first I didnt believe this. 3 months ago I formatted my Samsung SP1614C hard drive for the first time(except the first time I got it, so I guess I formatted it 2 times if you want to get technical about it). It was a 160 gig hard drive. Now I only get 130 gigs of usable space. Dont know what happened to the other 30 gigs, not that much of a problem either since I really dont even need 80 gigs of space, just kinda sucks that I am shorted 30 gigs. But my other 40 gig hard drive in my old computer, been formatted at least 20 times, and still workd perfectly fine. So I guess this is one of those debates.
ncantador said:Are you using XP, if so you probably formatted your hard disk with the original cd. which will not recognized drives bigger than 130gb. The remainder of your drive is probably on an unformatted partition. To check this go to start>settings>administrative tools>disk management. If the extra space is there, just format it and you'll get your space back.
ncantador said:. To check this go to start>settings>administrative tools>disk management. If the extra space is there, just format it and you'll get your space back.
deadman_uk said:You need to install Windows with SP2 intergrated into it, learn how to do it here http://www.winsupersite.com/showcase/windowsxp_sp2_slipstream.asp
the 30GB is not lost, you can access it by going to admin tools in control panel and going to Computer Management then disk management, partition the 30GB and it will create a new drive.
ncantador said:Glad to help you, lazy moron![]()
and thanks deadman for correcting me on that path to disk management, start>settings WTF was that!!
You probably have a Windows XP installation CD with no Service Pack whatsoever on it.Lazy_Moron said:Yeah you confused me there, and thats why I couldnt find it. Why does the installation CD limit you to only 130 gigs anyways? One day next month, whenever I get my Raptor, and a new motherboard with the 955X chipset in it(no dual core, just want to have that option in a year or so), I plan on formatting it again. How would I go about formatting it, and have all 160 gigs of it formatted at once? I do not plan on running RAID, just want a Raptor for the Operating system, my games, and for all my video editing programs and Visual Studio.NET then all the other Apps I run will be on my 160 right now
deadman_uk said:Ive heard people say that formatting your hard drive damages it.... is this true?
> see link for Myths 2, 3 & 4Myth #1 : Formatting a hard disk too many times will cause it to fail.
Truth : To put it shortly, formatting your hard disk will NOT reduce its lifespan. Yes, formatting is popularly thought to reduce hard disk lifespan but that is nothing more than a myth.
Formatting is NOT a stressful event for the hard disk. The read/write heads do NOT touch the platter surface, so damage to the platter only occurs if there is any shock to the drive during operation. You can format your hard disk 20 times a day, every day and it will not be more likely to fail than any other drive.
Myth #5 : If your hard disk has bad sectors, formatting will cause more bad sectors to appear!
Truth : If your hard disk has bad sectors from recurrent head crashes, then the number of bad sectors is GUARANTEED to increase as time goes by.
The reason for the increased number of bad sectors when you format the hard disk is because formatting your hard disk reveals the new bad sectors! Don't forget, when you format the hard disk, the format utility will check for and reveal the new bad sectors.
So, formatting will not increase the number of bad sectors in a failing hard disk. It just reveals what's going on.
