Formating question
Cryptic
Whats the difference between a Quick format and a full format on the Windows XP disk? Just wondering, thanks.
I believe the quick format justs allows the data to be written over. Wheras a full format actually erases the data. I may be wrong but that was my understanding of it.
For most cases a quick format is more than sufficiant. If you're getting mad chkdsk issues that won't go away a full format may help though.
Formatting does not erase the data...
Quote from microsoft Tech net
Quick format
Quick format creates the file system structure on the disk without verifying the integrity of every sector. Choose this method for any disk that has no bad sectors and no history of file-corruption problems that might be related to bad sectors.
Full format
A full format identifies and tracks bad sectors so that they are not used for storing data. Choose this method for any disk that has bad sectors or has a history of file-corruption problems that might be related to bad sectors.
http://www.microsoft.com/technet/prodtechnol/windowsserver2003/library/ServerHelp/c032e263-838c-43a9-840c-c8cf26077028.mspx
If you've got the time then a full format would be a better idea but as long as your drive is still in good order and your not reinstalling cause of a drive error then a quick format should be fine if your in a hurry :)
