I am trying to install Windows 98 on an old computer and I ran into a problem that I hope you guys can help me with. I reformatted the hard drive, it got to 100% and looks like it did the 20 or 30 times I have done this before so I put in the install disk and restarted. It booted off the cd and as I went to install it said there is already an OS installed do you want to install over it. I thought it was odd since I had just reformatted but I clicked yes only to get to the next screen that said it can't install over it press F3 to quit. I restarted and tried again and got the same effect so I took the cd out. It starts up like normal and it shows a Windows 98 splash screen for half a second. If you blink you would miss the splash and it goes to the dos prompt. I tried to format it again and it says command not found. Which I have never seen happen before.
So, I can't format it again and I can't install it. What is wrong with this thing and how can I fix it?
