Forcing UT2004 to USE SLI?
newls1
Im currently using 71.89 nvidia drivers, and they seem to DISable SLI support for ut2004. I've installed NHANCER, and using that program, it says "LOCKED" under SLI settings, so I cant FORCE AFR, or AFR2. The game runs fine with out it, but I would like to use SLI if possible. Is there a way to FORCE it?
With a single 6800 GT or Ultra you should be able to play at max settings and get around 100FPS.
Two Ultras would be somewhat of an overkill.
Try running UT2004 Icetomb at 4xAA/16xAF and eat those words. It gets as low as 30s there which is certainly unacceptable for a fast paced FPS like that. It would be nice to know that people can improve their frames here with SLI...
Have you created a UT2004 profile? You can also edit the existing one and create your own. Of course you have to do all the testing yourself for it.
