Forcing applications to launch on the secondary display
GK_3GO
Is there anyway I can force certain applications to launch on the secondary monitor by default?
I have my PC connected to my TV via an S-Video cable and use Firefly as my "Media Center." If I launch it, it always starts on my primary monitors unless I drag it over to the second monitor which is my TV.
Is there a setting in Windows that will force the application to launch on the secondary monitor?
If it helps at all I'm running and ATI Radeon X850 Pro.
Thanks a millions dudes! :)
I believe UltraMon can do what you need.http://www.realtimesoft.com/ultramon/
here are some features,
Get the most out of multiple monitors with UltraMon™
UltraMon is a utility for multi-monitor systems, designed to increase productivity and unlock the full potential of multiple monitors.
* efficiently move windows and maximize windows across the desktop
* manage more applications with the Smart Taskbar
* control application positioning with UltraMon Shortcuts
* multi-monitor support for desktop wallpapers and screen savers
* mirror your main monitor to secondary monitors for a presentation
Trying it out now...
yeah i use ultramon, if you didnt notice though it will need to be registered after 30 Days, just a little FYI.
ultramon is pretty much the standard for that stuff as far as I know. I've used it for a long time and it works great.
Would this work with an application such as MAME/MAME32 and other flavors of emulation?
