Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm playing hot pursuit and I notice jagged lines. Would I make the graphics better if i forced aa in ccc? Or if a game just doesn't have it do I let it be?
Usually forcing it from the CCC will help with games that don't natively support AA with minimal side effects(graphical anomalies and large performance hit). Hot Pursuit doesn't though so you should enabled MLAA for this game as it help a lot. You could also try forcing SSAA from CCC as I've found that 4xSSAA does help some. http://www.hardforum.com/showpost.php?p=1036451579&postcount=91
