Forceware 81.xx and Doom 3 problem ????
Braznor
I just installed the Forceware 81.xx drivers today for my XFX 7800 GTX. The problem is that when I run the Doom 3 test demo1, I now get 40 FPS average at 1600x1200 4x fsaa and 16x AA. whereas I was previously getting 53 or so. Remember I ran the test twice and now quoting the results of the second run. My config is as follows:
AMD 3500 at stock 2.2 Ghz (I dare not overclock it with my income :p )
2 GB RAM
XFX 7800 GTX at stock 450Mhz / 1,2 Ghz
Dual 7200 RPM SATA 160 GB hdds in RAID 0
Asus NForce 4 A8N-E motherboard
My 3DMark 2005 scores are now around 7845 for 1024x768 with no AF or AA and 6674 with 4x FSAA and 16x AF. Is this typical of my configuration especially with my 3500 CPU??? The other drivers like the Nforce mobo have too been updated to the latest drivers.
What happened was I uninstalled the old 78.03 drivers and then installed the 81.xx. When I restarted the computer, i tried running 3Dmark and then got a Direct3D error. I then uninstalled the 81.xx driver and then ran driver cleaner and then reinstalled it back.
Also I have not defragged the hdd for a long time, could this be a part of the problem ??/ I know the Doom 3 test caches textures from the HDD, this is why I suspect so :confused:
The game itself runs fine though, just the benchmark gives me the jitters. Is my video card failing ???? :eek:
Well, I defragged my HDD and then removed the 81.85 and reinstalled 78.01 back, the situation still remains the same. Doom 3 does not go beyond 40 FPS at 1600 * 1200 4x FSAA and 16x AF, what do I do now?????
Someone please help me :(
Do the whole driver cleaner routine. When that happens to me its usually due to parts of the old driver mingling with the new one...
Were you overclocking before using the forceware drivers? The overclock is always lost when you reinstall the drivers.
