- Feb 4, 2003
So I've been testing and it seems that these 180.43 drivers cause a weird texture flickering bug. It seems to be a shader related thing, but that's just a guess.
Any, the problem is as follows. In the screenshot below the bottom white/grey texture right under neath the exhaust pipes will flicker intermittently. It looks very remiscent of a Z-Buffer double texture flickering, or an overclocking artifact. However it happens when not overlocked. It doesn't happen on all cars, infact the only one I've noticed it happen on is the Lemans Audi T10 (or whatever it's called) as shown below:
It's most definitely a driver issue as any other previous driver I've tested the problem is non existant.
So is anyone else getting this issue with the 180.42 or 180.43 drivers, and if so/if not, what card are you using?
