force 16AF?
Terra said:
You might not be able to se any difference, but run those images through some software...
They are not 100% alike...only 99.1% alike ;)
Terra...
nope nothing was different. i did what bLaCktIGErs91said and NOW i can change the AF settings and they ARE noticable. so thanks but you were mistaken because it wasnt doing anything before. now when i am on high quality and change the AF in new Doom 4 profile it will actually change it in the game. now i can run ultra and and finally have 16 AF. me so happy. thanks to all those that tried to help especially bLaCktIGErs91.
trek554 said:
nope nothing was different. i did what bLaCktIGErs91said and now i can change the AF settings and they are noticable. so thanks but you were mistaken because it wasnt doing anything before.
I just did the renaming thing, same location CP set at 16xAF...
The difference between the CP application controlled and new screenshot:
Sorry, but I trust my software over your eyes...
Terra - Infact over anyones eyes ;)
i know what blurry grates and floors look like. now if a change the AF to 0 the grates are super blurry and when i change to 8 or 16 they are perfectly clear. if i use high or ultra quality and helps other thing besides Af. so the best image is in ultra with 16 AF set in the new Doom 4 profile. before when i changed the AF in the global settings it DID nothing.the global settings would probably work now since there is no Doom 3 profile at all.
trek554 said:
i now what blurry grates look like. now if a change the AF to 0 the grates are super blurry and when i change to 8 or 16 they are perfectly clear.
I can mail you the last screen and see if you can spot the difference visually? :)
Not the suttle changes in Wang & Bovik?
CP AF with and without renaming are not 100% identical, but they VERY close...
Terra...
CP AF and APP AF is not 100% identical, but they VERY close...
Terra...
you can if you want to. i have been at this for hours so i know what i did now made the difference and nothing else worked. i am telling you i can make the grates and floor blurry now even in ultra setting. that proves that the AF is actually being changed. before it made no difference on the grates and floor when i changed the AF in global settings.
Mail sent.
I think you messed up some where else, cause the software tells me the difference is 0.9% between my CP AF and my renamed CP AF compared to the APP AF shot.
Terra - But you got it working now...so in the end you did something right ;)
Terra said:
Mail sent.
it does what i want now and it is very noticable. man this went on for half the day. thanks for the help. time to take a break from posting. :D
Enjoy your gaming ;)
Terra...
