For those who are using SLI
holycpu
I want to ask you guys something.
I plan to get a SLI configuration for my new comp as well; however, there is one concern.
I planned to use Zalman VF700-Cu vga cooler for 6800GT and plan to put another one in future for upgrade. However, will it even fit ?
I mean, lets say this is the motherboard, then, the cooler will be attach to the card, then
6800GT and Zalman [maybe there is lil space left] 6800GT and Zalman
Is this even possible to fit all these 4 things on a motherboard? or I don't need 2 cooler for SLI, I should just use one instead.
(Don't plan to use water cux its not convinent)
or there are other method of cooling made for SLI?
Thanks for your help.
cell_491 said:
get an NV silencer 5
so............Zalman won't fit at all?
NV silencer 5 is a really good choice but it can't cool the video card ram, that's y i use Zalman instead.
It will but it will just blow hot air around the case.
The NV5 will push the hot air out.
