Does this NB frequency guidance apply to lesser AM3 chips as well? I just finished configuring an Athlon II 630 box for folding @3.4ghz with 2.43ghz on the NB. I should be able to raise the NB with a lowered multiplier, is this worth the effort?Its been a while since I did F@H with my 1055T but you should be looking around 11-15k ppd (if I remember correctly from the summer)
NB frequency plays a significant part in getting your TDP down along with the memory frequencies. You should try and definitely get over 2600 at least.
Here is what mine is OC at right now for BOINC projects:
1055T (125 watt version) - 255*14 (3570@1.375V) - I can get my chip up to 3976 (at 1.50V) but I don't like to keep it that high. It is very easy to get around 3.6 or so on stock voltage or a slight voltage bump especially if you have the 95W version. After 3.6-3.7 you start to need to add a lot of voltage to get your OC a lot higher. Additionally I know if you have a higher FSB (and lower multi) at the same speed you will definitely help your TDP. I would go that route first if your trying to maximize ppd and start at a 13-13.5 multi with a FSB around 280+. This way you can also get your NB frequency up as well.
NB - 10x (2.55GHz) with a voltage bump to 1.2
HT - 8x (2.040GHz) stock
8gb DDR1333 @ 1360 (1.5V)
I hope some of this was useful for you. You definitely can get around 4Ghz if you really want to push your chip but your going to be using a lot more power. To me it was not worth the 5-10% increase in points for a 30-45% increase in power.
with that kind of voltage on the cpu you should be able to hit 3.87 no probs with that chip...... mine does 3.87 with 1.38 volts that is on a cheap m3n78-vm you will have to tweak the nb and pll voltages a little bit but not that much. are you sure that your ram in not limiting you? drop the ram multiplier all the way down and just see what your max cpu mhz is. then work on the ram.....
What kind of cooling you running anyway? Temps?
is turbo boost or cool and quiet on???? these will limit your overclocks. I will iterate that turbo boost and CNQ are off on my system.
Some of the SATA device settings didn't like the new SATA III HDD and Blue Ray drives. So I reset everything.
If I can't get it back to 4 or close that's ok, this is a min rig first and folding second.
wow that chip has a high VID
You should be able to get the HT above 2000 bump the NB voltage up a little at a time this will enable your HT to go higher, The higher you can get your HT to run the faster the overall system performance, as this is the link between the memory, cpu, and IO
I did not say that it increased memory speed I said that it increased overall system performancethis is because it is the "link" speed between CPU -> IO -> Memory Channels, It has nothing to do with memory per say , just the communication speed across the bus
And no offense taken
