I have been using a Sony Multiscan G420 for around 6 years now. it started having a lot of problems like fuzzy views, too bright backlight(had to set brightness down to 0) and I can even see red/green/blue lines across the entire display.. (i thought the Monitor is broken)
just now i was playing around with the settings again
and found a function called "Image restoration" in the "preset mode".. not knowing what it does i pressed it anyways .. you prob. wont believe it but the monitor has become NORMAL again!! the color has become so rich and the RGB lines are gone too!!
just wanted to share
Mike
Mike
