Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
However, unless I'm missing something, it seems the input for the reservoir is waaay too close to the output. It looks like the flow would go in, hit that angle, and go towards the rear of the reservoir, while the pump is sucking in, creating a lot of turbulance and reducing flow...
Then again, that's just how it looks on the outside.
edit: Waitaminute.
How the hell do you fill the system? There's no filler hole in the reservoir it seems. Reservoir + T-line? That would be stupid.
editedit:
Nevermind. I was looking at the pics on Sidewinder...which all show it upside down. There's a filler port on the other side.
