For all the poor people
Shmuckety
I just figured I would write this little post because alot of people out there are strapped for cash and still want to game.
I enjoy PC games and I want everyone to be able to do the same. So to get to my point.
I recently bought the Oupost's $150 PC (now 179, i think). This is a great system. It has a 2200 (1.5Ghz) sempron that will easily overclock to 1.8Ghz (400FSB). This overclock will allow you to use PC3200 memory.
Therefore this is all you need. If you have an aging system and want to buy something good, but only have a budget big enough to buy a video card. Then this is what you need to do.
Also let me note that there are not alot of PC skillz necessary either. :D
Buy 2200 sempron system from outpost: Info Here
Comes with KB, Speakers & Mouse
Buy 6800LE from Newegg: Info Here
Buy memory at local store.
PC : $180 + 6800LE : $130 + 512MB PC3200 : $30 on sale=
$340 for a great little gaming system.
When the system goes back on sale it will be even cheaper.
That's all. Thanks. :)
thanks but no thanks. i like to play my games with a little eye candy. a 8pipe 6800le just wont cut it. i like my X850XT :). but thats not the point. this thread is for poor people who want to game. oh and, a 9700pro runs bf2 fine, but with no aa.
Yes the link is dead. I am pretty sure that is temporary because I just got an email from them advertising this PC.
I just hate to see people with this in their sigs:
P2 333mhz @ 335mhz
272mb PC133
GeForce2 mx
becasue they are saving up for “the big upgrade” which may never come. You don’t have to spend $400 on a video card to play the latest games.
Rock on :p
P2 333mhz @ 335mhz
272mb PC133
GeForce2 mx
Rock on :p
First of all... Hey! My P3 450 rocks when playing tetris! :p
Seriously though, here are a few questions...
How easy is it to overclock that mobo? I'm not very familiar with OCing.
Will you need a better hsf for the cpu?
How are you able to use faster ram after the OCing?
Well...All you have to do is press the del key when the computer is booting up and that will take you in to the BIOS.
Once in the BIOS you just have to find the correct area and change the number from 333 to 400 and your done.
I can explain in more detail once I get back home so I can see what all the correct names of the menu's are and what not.
By changing that number (FSB) and also changing the RAM settings in the same window you make the ram run at the same speed as the FSB of the processor, which in this case is 400mhz. :p
If any of that makes sense to you...then you are well on your way. :D
and no you will not need a new Heatsink.
That sounds freakin easy! I always though OCing meant changing dip switches and jumpers on the mobo and installing massive cpu cooling fans.
Dip switches were from the pre pentium 4 era and Stock heatsinks can usually handle a pretty good overclock.
Its not that hard, but it takes a little time to test and make sure the CPU can handle the OC by running Prime95 or whatever. This processor handles 400FSB quite well.
Also this system does not come with any fans inside, so you may want to get one. I am not currently using one (by the way I have this system) and it seems fine.
I have the same system, and for $149.00 I feel it was a great deal. I cannot make a claims for reliability after only five weeks, but I will keep my fingers crossed. Outpost frequently has these on sale for $149.
Shmuckety you really should throw a 92mm fan in the back opening as the inside of the case gets a tad warm under load without it. Also, I would not try putting anything higher than a TI4200 card in this sytem without changing the power supply first (That SVC $25 AMIR Cooler Master PS last week fits the bill perfectly.). Just my $.02.
what are you temps, out of curiosity?
looks like a great system for the price, good work man.
Honestly I have no idea what the temps are. It hasn't rebooted and it is folding 24x7.
I can't find a program that can give me temp readings. MBM does not support this mobo yet and I really don't know where else to look.
The PS is holding up fine, so far and I think the PS is what is exhausting all the heat. :p
If anyone knows of a prog that support this mobo let me know. The mobo is an ECS 741GX-M
http://www.ecs.com.tw/ECSWeb/Produc...nuID=24&LanID=9
You can build a much better system for close to that cost for example
Amd x64 2800+
socket 754 motherboard
512mb ram
6600gt agp
case and ps
mouse & keyboard
15' monitor
Could have all that for under 450.00 bucks if you buy the componets off pricewatch.com and would have a computer for only 100.00 bucks more that would blow the socks off that system you mentioned.
I agree with shane. If you are value-oriented and need to game, I built this on newegg for 480.
Rosewill R103A Case w/350w PS
Rosewill RD-162X DVDRW
Western Digital Caviar SE 160GB HD
ECS NForce4 Mobo
PNY 6600GT AGP
PQI 512MB PC3200
AMD Sempron 64 2600+
Logitech Internet Pro Mouse/KB Combo
You could go with a 40GB Hard drive and up the processor to a Sempron 64 3000+ for the same total.
That's true, but personally I would not want to buy parts from some of the stores that are selling stuff for the lowest price on pricewatch.
Thanks for the suggestion, but this was intended for everyone not just paople that could assemble an entire computer themselves. Also some people can barely spend this much let along another $100.
Hooray for cheap *ss PC's that get the job done! I'm downgrading my computer myself at the moment.
Well I tried the program Speedfan. It is telling me that temp1 (i am assuming is the processor) is at 50C. This is at full load.
The specs that I could find said that max for the sempron is 90C. Does anyone know if this is true? What are good temps for the sempron?
With the unlocks and overclocks the 6800LE is a much better buy than a 6600GT.
but you also have to think (the one who said you can build a great kickass for 100 more) ... that you hav ea 754 socket when that'll die soon and go 939 i'm sure. Becuase 939 will be here for "awhile" considering it also supports dual core
But we're looking at bargain based pcs, I'm pretty sure most of these buyers will be more interested in out of box performance.
How so? If people don't have a lot of money, myself included, I generally tend to buy something on the cheaper side and tweak it to no end.
That's why.
