for $1100 damage... how did I do?
mxpxrulzz
Well, I have been reading up on my stuff for about 2 weeks, this is my first build since the rig in my sig 4+ years ago... The straw that broke my back was my 9800 pro taking a crap... you can only deal with a 16mb tnt vanta for so long :eek:
in retrospect,.. did I make the right decisions? I got a little careless with the video card purchase as I just couldn't bare to wait around for prices to drop. I will be using this for alot of multitasking (web development stuff) and some gaming.
q6600 b0 OEM $262.99
Zalman CNPS 9500 $43.99
2 x (1 GB patriot ddr2-800 4-4-4-12) $44.99
Abit ip35-E $89.99
EVGA 8800GT KO $309.99 :eek::(
Corsair 550VX $89.90
Antec P180 case $122.50
Logitech ultrax keyboard $18.99
Logitech mx518 $40.99
250GB WD 16mb SATA hdd $69.99
grandtotal : $1094.32
with shipping: $1124
I know I could probably have saved $50 on the video card if I waited but other than that does it look like I made the right choices?
Also quick question... is it ok to mix memory brands in the future as long as they have the same timings? I got a deal on the patriot sticks (rebate) but didn't want to get 2 sets because of the turnaround. Would I be ok to pick up the same speeds down the road but from a different brand? (no ocing just stock speeds)
Ditch the Zalman and get this.
http://www.svc.com/acfzp7.html
If you want ultimate air cooling, then get Thermalright Ultra 120 Extreme + Scythe SFF21F fan.
http://www.svc.com/ultra-120-extreme.html
http://www.svc.com/sy-fan-sff21f.html
250GB is not worth, get 320GB or even 500GB.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
I wouldn't buy 8800GT for $310. Just buy for $269 and OC it for your self. Other stuff looks good.
Yes, the Arctic Freezer Pro gives the Zalman a run for the money and costs so much less.
I'm only planning on a modest overclock (3 ghz) and I liked the way the zalman looked :p I'm sure it will do fine with my setup
I have another 250gb sata drive and evetually I will get another massive drive for storage. I reformat alot and i doubt I would even fill the 250 before its time to "wipe it down"
and yeah i got raped on the 8800GT, but I can't find the $270 cards in stock ANYWHERE and if I didn't make a move now, I would be without a running system for probably a week or 2.. way too long :D
Yah, I would have advised against the zalman, too. Otherwise, not bad.
Check your local Best Buy. I checked the one near mine and they still have a couple on the shelves for $279 (BFG 8800GT)
