Foobar skin question
B
bostesseger69
Guest
Does anyone know of one that is setup mostly like iTunes, or at least has most off the functionality that iTunes has? I'm tired of iTunes. :rolleyes:
If you want itunes; use itunes.
You should reword your question to be a little more specific; Foobar is a great program.
iTunes sucks though. Also, I think the wording is pretty specific, the title explains it is a skin question, and I then ask if anyone knows of one that is similar to the functionality of iTunes. Pretty explanatory.
As a foobar user, outside of the appstore, I actually have no idea what functionality iTunes has, hence my poorly worded (my apologies, running on no sleep) request for explanation of what you want that is not stock on foobar.
I just meant it has the graphical interface of iTunes. Aka: it shows what artist the song is sung by and you can sort by artist, you can sort by the genre of music, you can sort by the album, you can make playlists, etc. Sorry, my response was sort of assholeish as well. Same problem for me, not sleeping well at all since my accident.
View>layout >quick setup
Pretty much anything including album list will make you happy, you can adjust things to match what you want from there.
http://foobar2000.audiohq.de/foo_facets/screenshots
heres a shot of my foobar
good nuff? :D
Yeah actually, link me, or explain to me how in noob terms! PLZ!
some of those themes can be downloaded and imported. you can try deviant art. the forums for foobar (hydrogen audio) have a huge thread about user themes too.
its a ui plugin called "facets", apparently its part of the default ui now
so just install the newest foobar, go to view> layout >quick setup to preview some layouts
Just install it and try it :p
Personally I like foobar because its such a simple and low resource program.
I've gone to where you have told me to go and have had the latest foobar installed since I started the thread, however I do not see any "themes" and in the categories that are available there is no "facets". Another idea perhaps?
As I said above in that reply, I've had it installed since thread start.
