I got the Syntax Olevia 27" LCD TV and using with Charter cable at the moment picture quality is okay not bad but not spectacular either. The colors look a little washed but so did the 42" plasma Samsung panel I hooked up through component. The Syntax looked beautiful with the OTA HDTV tuner from Radio Shack too bad no QAM. I had some questions I can get the 32" for a little over $300 more is it worth it? I'm buying a HDMI to DVI, RCA, Optical Toslink, and component from monoprice to use with the TV and HT components. Is 6 ft plenty or should I get longer ones? I listened to the Micras and they sound okay but I feel I can get something better for the money maybe. Are the Micras considered substantial for HT use in a 1 bdr apartment or should I get something like the Polk speakers RS15 for now and upgrade later if need be? Is it worth it to get 5.1 or can I get away with 2.1 and combo it with Dayton 12" for DVD movies and divx TV episodes? Also anyone recommend a cheap place to get speaker stands? I fear the move with all this heavy stuff again because of the rush move and neighbors complaining. I blasted the MX5021 and got a couple of bangs already. I can only imagine a HT setup.
P.S. The receiver would be the HK AVR 235 unless someone can recommend something better.
