TechloGoblin
- Oct 20, 2009
I can confirm that I have BOTH of my 5870's folding with the Crossfire bridge on AND enabled!
I followed this guide: http://www.bit-tech.net/bits/softwar...folding-home/4 as a basic reference
and it's pretty self explanatory:
the first shortcut you create is for GPU0(the main video card you use). When you right click and goto properties the Start In: should look like this: "C:\Program Files (x86)\Folding@home\Folding@home-gpu" (I am using Win64 Pro for reference I believe the dir is slightly diff with XP as shown in the link above)
GPU0's shortcut Target should look like this: "C:\Program Files (x86)\Folding@home\Folding@home-gpu\[email protected]" -forcegpu ati_r700 -gpu 0
GPU 1's shortcut Start In should look like this: C:\users\xxxxx\AppData\Roaming\Folding@home-gpu_1 (xxx representing whatever username you login to your PC as)
GPU 1's shortcut Target should read like this: "C:\Program Files (x86)\Folding@home\Folding@home-gpu\[email protected]" -local -forcegpu ati_r700 -gpu 1
When you create the 2nd shortcut using the -gpu 1 flag it is basically forcing the 2nd 5870 to use its GPU...I can ABSOLUTELY confirm this is working as it shows up within FAHMon properly...
so now I am using 7 cores on my VM, I am using the other core for GPU 0 and 1....
I also confirmed within MSI Afterburner that both of my Crossfired GPU's are being utilized..and each one hovers around 80% utilization.
I am watercooling and I am monitoring my temps and everything appears just fine...
That my ATI friends is how you rig it to work with Crossfire enabled AND being able to keep the Crossfire bridge attached!
not bad for a [H] folding noob 'eh?
