Air Cooled 420
- May 10, 2006
There's also the new Penryn instruction set, but that will need to await for Stanford's support before we see a performance boost. So far, it's not too shabby. Spending a little more for a 45nm chip instead of a 65nm part will yield benefits in the long run.A bit of a bump in IPC but not too much ahead of the G0. Wish they could to 4 GHz. Then they'd have the IPC and clock advantage.
I had the box on a kill a watt meter before and after.
The before was with a Q6600 G0 @1.425 3.5Ghz, about 283 watts
After X3350 @1.4v @3.5Ghz about 45 watts less, about 235 watts
There is also a 8800gts in box, causing the high wattage readings
update: obviously I must dump this video card and build new box
I don't remember the last time I gamed, all boxes must fold![]()
You're determined to help find the cure for cancer. Good job.
