Folding stats not recorded
byusinger84
I'm having an issue where it seems like everything is running just fine, but my stats are not updating like they are supposed to. I upgraded almost all of them this summer, but since that time I'm only getting around 9,000 points a day. I should be getting well over 60,000 as that's what I was doing before on the older hardware. Most everything is a Quad Core Xeon (socket 1155) and is plenty fast for folding. Below is my log...any help would be appriciated because I don't know what else to look at.
This is just the latest snipit:
15:52:47:WU01:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
15:53:56:WU01:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
15:53:57:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
15:53:57:WU00:FS00:Connecting to assign3.stanford.edu:8080
15:53:57:WU00:FS00:News: Welcome to Folding@Home
15:53:57:WU00:FS00:Assigned to work server 171.67.108.60
15:53:57:WU00:FS00:Requesting new work unit for slot 00: RUNNING smp:8 from 171.67.108.60
15:53:57:WU00:FS00:Connecting to 171.67.108.60:8080
15:53:58:WU00:FS00:Downloading 940.64KiB
15:53:58:WU00:FS00:Download complete
15:53:58:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:8049 run:443 clone:2 gen:58 core:0xa4 unit:0x000000506652edcc50133323aafb220f
15:54:07:WU01:FS00:0xa4:
15:54:07:WU01:FS00:0xa4:Finished Work Unit:
15:54:07:WU01:FS00:0xa4:- Reading up to 1406148 from "01/wudata_01.trr": Read 1406148
15:54:07:WU01:FS00:0xa4:trr file hash check passed.
15:54:07:WU01:FS00:0xa4:- Reading up to 851348 from "01/wudata_01.xtc": Read 851348
15:54:07:WU01:FS00:0xa4:xtc file hash check passed.
15:54:07:WU01:FS00:0xa4:edr file hash check passed.
15:54:07:WU01:FS00:0xa4:logfile size: 22866
15:54:07:WU01:FS00:0xa4:Leaving Run
15:54:11:WU01:FS00:0xa4:- Writing 2285766 bytes of core data to disk...
15:54:12:WU01:FS00:0xa4:Done: 2285254 -> 2190410 (compressed to 95.8 percent)
15:54:12:WU01:FS00:0xa4: ... Done.
15:54:19:WU01:FS00:0xa4:- Shutting down core
15:54:19:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
15:54:20:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:54:20:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:8049 run:227 clone:2 gen:65 core:0xa4 unit:0x000000716652edcc50132e4336a62f4d
15:54:20:WU01:FS00:Uploading 2.09MiB to 171.67.108.60
15:54:20:WU01:FS00:Connecting to 171.67.108.60:8080
15:54:21:WU00:FS00:Starting
15:54:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 2564 -checkpoint 15 -np 8 -service
15:54:21:WU00:FS00:Started FahCore on PID 3924
15:54:21:WU00:FS00:Core PID:3952
15:54:21:WU00:FS00:FahCore 0xa4 started
15:54:21:WU00:FS00:0xa4:
15:54:21:WU00:FS00:0xa4:*------------------------------*
15:54:21:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
15:54:21:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:54:21:WU00:FS00:0xa4:preparing to commence simulation
15:54:21:WU00:FS00:0xa4:- Looking at optimizations...
15:54:21:WU00:FS00:0xa4:- Created dyn
15:54:21:WU00:FS00:0xa4:- Files status OK
15:54:21:WU00:FS00:0xa4:- Expanded 962701 -> 2211692 (decompressed 229.7 percent)
15:54:21:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=962701 data_size=2211692, decompressed_data_size=2211692 diff=0
15:54:21:WU00:FS00:0xa4:- Digital signature verified
15:54:21:WU00:FS00:0xa4:project: 8049 (Run 443, Clone 2, Gen 58)
15:54:21:WU00:FS00:0xa4:Assembly optimizations on if available.
15:54:21:WU00:FS00:0xa4:Entering M.D.
15:54:23:WU01:FS00:Upload complete
15:54:23:WU01:FS00:Server responded WORK_ACK (400)
15:54:23:WU01:FS00:Final credit estimate, 1761.00 points
15:54:23:WU01:FS00:Cleaning up
15:54:27:WU00:FS00:0xa4:Mapping NT from 8 to 8
15:54:28:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
15:55:37:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
15:56:46:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
15:57:56:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
So I'm going to assume that I'm being blocked or filtered in some way. I have access to the filters (we use Cymphonix), but based on the logs it doesn't appear the upload failed in anyway, so I'm just guessing. Aside from the server upgrades this is the only new device between the servers and the internet. Anyone have any idea what exceptions I need to put in to allow comminucation to work properly?
The good thing is the log snipet does show the WU number. Maybe someone like Grandpa_01 that has the knowledge can track down the status of it.
I would ask a mod over in the FF what's going on. Your getting bonus points so your passkey is working ok but you don't seem to be getting anywhere near the points you should be getting.
