Folding on multiple computers - Questions/concerns
Noah
I formatted my hard drive a while back, and just got around the reinstalling F@H. I installed it here as Machine ID 1. I pressed "Enter" after entering all the options and the following came up.
I hope this means that it will work with my old stats/work units. The same came up on the second machine I installed it on (an addition 2.8 GHz folding on top of this 1.8 ;)) (I gave the second one Machine ID 2).
Is this OK? Is it all going to work out?
Edit: How long should it take to complete a work unit on a 1.8 GHz Pentium 4 (Williamette) and a 2.8 GHz Pentium 4 (Northwood "B," no hyperthreading)?
No, it's not OK - the team number is supposed to be #33 if you would like support from this forum.
Sorry, but I needed help, thought the good people at [H] would help out.
I participate on Team 77 for AlienSoup.com - a forum I have visited since a few years ago.
That appears to be OK, as long as you make sure it assigns different IDs to each machine / CPU you should get full credit.
WU processing times will vary and depend upon the protein it's working and any coding optimizations you use.
