Folding@Home Questions? - Basic
AMD_RULES
I just got up and running a small file server @ home with the following specs:
AMD Opteron 144
Asus A8V-VM
Corsair XMS 512MB DDR PC3200
Seagate 120GB SATA150
Windows Server 03 Enterprise Edt.
What should I setup to fold? Just the basic client? :confused:
Thanks!
That is a single core chip, right?
If so, you'll want to stick with the standard client...
1.8GHz single core.
Run the standard console client.
Oh, and good to see ya AMD_RULES, it's been a while. :)
genome@home P: 54286.28
Good lord man..... that's quite a sig you have there relic:)
hehe... Yeah, I kept getting ragged on about not using the badges....
Figured this would get my point across. ;)
I can't use 'em....I take up too much real estate.
As advised above, use the standard no-nonsence console client. I prefer running the client as a service (an option when you first set up the client) as it will run without needing a user to be logged on.
Welcome!
Thanks guys
I installed the client and i'm up and folding.
I'm gonna try to build another rig with a E2180 and fold it too :D
It is a single core cpu
Thanks guys
If you can spring just a bit more for a E4500 you will get much much better results. See sig, My E4500 wipps my E2160.
