Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
alright im getting around 1000 and im looking to buy a foldingfarm i was thinking some chep cpu's and cheep mobos ram and power so what exaxt parts would you sugjest i want atlest 5 layers
X2 5 of those makes 10 clients... It might cost more but factor in price of e and only getting 1 motherboard and psu per chip i think it is a better price in the long run
I think 5 would be a little too expensive Duster. X2s are about $270 each and he only has $1000. michaelpi would only need to consider the price of procs, mobos, and power supplys and ram, since he can install foldix or foldserver large hard drives aren't need. With foldserver only 1 harddrive would be needed.
2 X2s for $540
2 mobos for $200
2 psu for $100
2 x 2x512mb ram for $160.
Leaves 40 for cases and or better mobos. [H]ard people wouldn't use cases
That is 4 clients. You could OC the X2s to 2.5ghz and be good. Someone chime in with the ppd michaelpi could expect.
You may want to take a look here... With alot of help from the guys here, I've set up a page to see basically what the cheapest recommended parts would be...
My advice would be to mix it up a bit... get a little intel, and little AMD...
