velusip
- Jan 24, 2005
Tinkering with Rivatuner to make a more stable fold for the gpu client. Reduced the clocks and increased the top end of the auto fan speed control.
eVGA 8800GT underclocked to 450/1125/754
duty min 31
duty max 100
t min 50
proposed top end 75 degrees (subtract 10 in my case to get surface temp)
t range 14 or 2.0/3.0*(65.0-50.0)/(1.0-0.31)
60 degrees idle (48 degrees ambient, 40% fan)
70 degrees folding (57 degrees ambient, 93% fan duty)
That huge ambient temp change is probably partly due to the bad stock cooling design. Mine intentions were to underclock to help keep the temps down so the card can fold for longer periods without error and probably improving long time yield as the servers will refuse your work for 24 hours if you submit too much bad data. This particular card is known for overheating and has been folding for months now with stock settings-- blame my ignorance. I think it's almost ruined at this point... final trial in progress!
duty min 31
duty max 100
t min 50
