Hello!
In ipad, how do i:
- create a folder, and where I will transfer pdf and put files from my pc
- how I transfer the files via the ipad cable
- how do I open ppt in ipad
-iPad doesn't support folders in the traditional sense. Files are stored with the application they are opened with.
-You can transfer files by using iTunes or 3rd party software such as Dropbox. SMB shares can be accessed using a paid app Filebrowser but IMO its a feature that should have been built in.
-Documents to Go can open ppt files.
A side note: If you are looking for a traditional folder file system an Android tablet is the way to go. File Manager HD can access network shares and it's free. Documents to Go has an Android version as well.
it seems that once you open a file in dropbox, it first downloads it and the second time you open it, it is locally stored and no wifi is needed (with limit of 500MB maybe??)
