Buying from scratch but I find I don't want to mess with Ivy Bridge for my new machine due to the TIM issue. It may not matter to some, but I hate it and don't want to delid and chance ruining the CPU, and I don't want to live with it. I want to water cool with a fluxless soldered CPU. I want to run my 680 Lighting alone for now, I may or may not buy another to SLI. Leaning towards just sticking with single GPUs, upgrading every year or two. Blu Ray Ripping/Transcoding, Adobe Photoshop and Illustrator, Gaming, and general high end PC build are the uses currently. And I really dig the top end Asus ROG boards. No good reason, looks, bells and whatnot. Had several already from the series and I love them. Driver/Bios support is always good and I'm building a showpiece for my first water cooling system in a Case Labs case.
So that leaves my options at:
1. Buy a Rampage IV Extreme and a 3830 and then an Ivy Bridge Extreme as soon as they come out.
2. Buy a Rampage IV Extreme and a 3930K and then buy an Ivy Bridge Extreme mid life cycle or when a good deal hits. Optionally just keep the 3930K if the upgrade will not be worth it. But I would not want to ride a non K CPU forever, so a 3830 is a stop gap.
3. Buy a Maximus V Extreme, get a 2700K, hope that Haswell has fluxless soldered CPUs.
4. Use a laptop until Haswell, hope it has fluxless soldered CPUs.
5. Use a laptop until Ivy Bridge Extreme, get a better chipset specific to that CPU, hope it has fluxless soldered CPUs.
6. Buy a cheaper Mobo/CPU set up for now, go all out when Haswell or Ivy Bridge Extreme comes (the first to have fluxless soldered CPUs)
I know some of you say hey what's the big deal, ivy is ok... But I know myself, I just got out of an Ivy Bridge system, I'll just try to delid it and then I'll ruin it. So I am removing that aspect completely. I'd rather just pick up a laptop and wait vs dealing with this TIM issue again. I want to OC without that limitation and I decided that deliding isnt for me. The money difference in these plans is not a deal breaker thing, I just want thoughts on the best path, given where we are in the life cycle. And sure I like value for my money at times, and others I go all out regardless of value.
