FLUKE 52 II or what?
ViperPrime
HI, i know that the FLUKE 52 II is king of the hilll
but it's always over 200 smolians
i just saw the
Type K E J T B N R S Digital Thermometer Thermocouple mV 1800°C High Temperature fpr $43.00 so that is big savings.....
anyone got something to say...
Description
This is a Professional Digital Thermometer which supports 8 Type of Thermocouples (Type K E J T B N R S) for extra high temperature measurements. You can replace the thermocouples with any standard Type thermocouple for your purposes.
The Thermometer has advanced features with 4 digits Dual Level LCD Display and able to display Higher Temperature Range (up to 1800 °C / 3272 °F), Higher Resolution (up to 0.1 °C / 0.1 °F) and Higher Accuracy. It can be switchable between °C and °F. It also has 2500 records of manual memory and 6000 records of auto memory.
Moreover, the thermometer can display Temperature of 2 different probes (T1 and T2), Temperature difference (T1-T2), Maximum (MAX) and Minimum (MIN) temperature. It also has 2500 records of manual memory and 6000 records of auto memory. Over Range, Low Battery Indication and Data Hold function are also included.
It has a wide range of applications in Ovens, Furnaces, Ceramics, Pottery, Molten Metal and many other industrial uses.
Features
Support 8 Types of Thermocouples (Type K E J T B N R S)
Thermocouple Type display
Wide measuring from -200 ~ 1800 °C or -328 ~ 3272 °F (depends on the thermocouple type used)
Large (3 inch) 4 Digits LCD Display
Dual Level LCD display T1, T2 and T1-T2
Maximum (MAX), Minimum (MIN) and mV Value
Memory Function: 2500 records of manual memory, 6000 records of auto memory (interval of logging time can be adjusted, longest time is 99 hours)
Viewing of Memory data
Fast Sampling Rate (up to 2.5 time/seconds)
Over Range and Low Battery Indication
Data Hold Function
Switchable between °C and °F
Alarm setting of High and Low Temperate Limit
Cold Junction Compensation
Factory Setting Reset
Set of 2 Metal K-Type Thermocouples Included
Specifications
General Specifications
Display: Large 4 Digits Dual Level LCD Display (3 inch)
Sampling Rate: 2.5 time/seconds
Over Range Display: display "-OL-"
Low battery indication
Manual Memory: 2500 temperature points
Auto Memory: 6000 temperature points
Working Temperature: -10 ~ 50 °C (14 ~ 122 °F)
Working Humidity: < 80%
Storage Temperature: -20 ~ 60 °C (-4 ~ 140 °F)
Storage Humidity: < 80%
Power: 1 x 9V 6F22 Battery (not included)
Battery life: Alkaline Battery (about 150 hours), Carbon Battery (about 60 hours)
Size: approx. 130 (L) x 85 (W) x 28 (D) mm (5.12 x 3.35 x 1.10 inch)
Weight: approx. 190 g (6.7 oz) (battery excluded)
ther spec seems good;;;;;;\\\
One Set Included
1 x Multi-Channel Thermometer
2 x K-Type Metal Thermocouples
2 x K-Type Wire Thermocouples
1 x Instruction Manual
Standard Factory Package
thoughts????
Any meter that can take a thermocouple will do. You don't need extreme precision or ranges, just find one that takes a k-type thermocouple and then buy a cheap thermocouple.
that is kinda what i thought, just need to know i am in the right range..
thanks
