FluidXP + Yea or Nay?
Nea
What I have read from users its not worth it do to the unbalancement of performance: price....and a few other bad things
Consider the MCT-40 from DangerDen if you can get it in stock! So far based on user reviews its the best of the non conductive products without the cons produced when using fluidxp
As long as you are careful when building your loop and leak test everything for at least 24 hours, there isn't a reason to get something like FluidXP. Distilled water will work just fine, and cost 80 cents as opposed to 40 bucks.
Nay...
Distilled water with 5 - 10% antifreeze (and dye if you are so inclined) is the way to go. Nary a growth in 9 months within the system.
Cheap. Effective. Easily replaced.
nay:
distilled water and coolant additive works better, is cheaper and is damn close to being non-conductive.
