This is my first post here at Hardforums, and I am told that this is one of the best forums for troubleshooting there is, so here it goes....
I am build a new computer (It's screaming fast) and I want to use a RAID-0 setup. I set it up in the bios, and everything was going well until, when i tried to make a bootable floppy, it said that there was no floppy drive connected!
So i proceded to check the motherboard and floppy connections, which were all good. I also checked the bios to make sure that the drive was configured properly, which it was, and tried again, but to no avail! I then tried a floppy that i know works, and did all of the same checks, ect. but it still wasnt there! The drives are also getting power because the green light goes on when it is supposed to.
I am using an A8R32-MVP and an NEC floppy drive, and the second one a Sony floppy drive.
