ValeX said:@OP - Your video card is too hot. Cool that biznitch down....
ValeX
System Information
Time of this report: 4/27/2006, 14:55:15
Machine name: JIMBOX
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: Gateway
System Model: EMACHINES
BIOS: Default System BIOS
Processor: AMD Athlon(tm) 64 Processor 3200+, MMX, 3DNow, ~2.0GHz
Memory: 1408MB RAM
Page File: 291MB used, 1541MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6100
Manufacturer: NVIDIA
Chip type: GeForce 6100
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0242&SUBSYS_72071462&REV_A2
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.8133 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/18/2005 11:32:00, 3905408 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 9/18/2005 11:32:00, 3493984 bytes
Device Identifier: {D7B71E3E-4102-11CF-1768-0D5203C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0242
SubSys ID: 0x72071462
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_1462C603&REV_1008
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5152 (English)
WHQL Logo'd: Yes
Date and Size: 9/14/2005 14:38:00, 3856896 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x026D
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 15:00:00, 57600 bytes
| Driver: usbd.sys, 8/4/2004 15:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 15:00:00, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 15:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/3/2004 20:01:08, 40840 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 8/3/2004 17:58:34, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: SoftV92 Data Fax Modem with SmartCP
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 137.8 GB
Total Space: 147.8 GB
File System: NTFS
Model: ST3160021A
Drive: D:
Free Space: 2.5 GB
Total Space: 4.8 GB
File System: FAT32
Model: ST3160021A
Drive: E:
Model: LITE-ON DVDRW SHW-1635S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 15:00:00, 49536 bytes
System Devices
Name: Linksys Wireless-G PCI Adapter
Device ID: PCI\VEN_1814&DEV_0201&SUBSYS_00321737&REV_01\4&2B17F62E&0&3080
Driver: C:\WINDOWS\system32\DRIVERS\RT2500.sys, 3.00.0003.0000 (English), 4/21/2005 15:56:10, 242176 bytes
Name: SoftV92 Data Fax Modem with SmartCP
Device ID: PCI\VEN_14F1&DEV_2F20&SUBSYS_200014F1&REV_00\4&2B17F62E&0&3880
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_CNXT.sys, 7.12.0009.0000 (English), 6/17/2004 18:55:38, 685056 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFHWBS2.sys, 7.12.0009.0000 (English), 6/17/2004 18:56:22, 220032 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSF_DP.sys, 7.12.0009.0000 (English), 6/17/2004 18:55:04, 1041536 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0006 (English), 3/17/2004 15:04:14, 13059 bytes
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\HSFProf.cty, 6/17/2004 18:30:54, 129045 bytes
Driver: C:\WINDOWS\system32\mdmxsdk.dll, 1.00.0002.0006 (English), 3/17/2004 15:00:32, 86016 bytes
Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_VEN_14F1&DEV_2F20&SUBSYS_200014F1\HXFSetup.exe, 3.00.0006.0000 (English), 7/8/2004 13:29:42, 540672 bytes
Driver: C:\WINDOWS\system32\HSFCI011.dll, 1.00.0000.0011 (English), 8/4/2004 18:34:48, 39018 bytes
Name: nForce Memory Controller
Device ID: PCI\VEN_10DE&DEV_02FF&SUBSYS_72071462&REV_A2\3&267A616A&0&05
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02FE&SUBSYS_72071462&REV_A2\3&267A616A&0&02
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_02FD&SUBSYS_00000000&REV_A1\3&267A616A&0&18
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 15:00:00, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_02FC&SUBSYS_00000000&REV_A1\3&267A616A&0&10
Device ID: PCI\VEN_10DE&DEV_02FB&SUBSYS_00000000&REV_A1\3&267A616A&0&20
Name: nForce HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_02FA&SUBSYS_72071462&REV_A2\3&267A616A&0&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F9&SUBSYS_72071462&REV_A2\3&267A616A&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F8&SUBSYS_72071462&REV_A2\3&267A616A&0&03
Driver: n/a
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_02F1&SUBSYS_72071462&REV_A2\3&267A616A&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027F&SUBSYS_72071462&REV_A2\3&267A616A&0&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027E&SUBSYS_72071462&REV_A2\3&267A616A&0&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0270&SUBSYS_72071462&REV_A2\3&267A616A&0&48
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_026F&SUBSYS_00000000&REV_A2\3&267A616A&0&80
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026E&SUBSYS_72071462&REV_A2\3&267A616A&0&59
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 15:00:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 19:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 15:00:00, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:44, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026D&SUBSYS_72071462&REV_A2\3&267A616A&0&58
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:38, 17024 bytes
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_10DE&DEV_026C&SUBSYS_10EC0880&REV_A2\3&267A616A&0&81
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 19:07:18, 138752 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0269&SUBSYS_72071462&REV_A1\3&267A616A&0&A0
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.5009 (English), 7/29/2005 20:11:04, 12928 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0000.5009 (English), 7/29/2005 20:10:46, 301312 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.5009 (English), 7/29/2005 20:10:32, 221824 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 7/29/2005 20:09:46, 9728 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 7/29/2005 20:09:46, 9728 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0029 (English), 7/29/2005 03:25:32, 33280 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_0266&SUBSYS_72071462&REV_A1\3&267A616A&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 15:00:00, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 15:00:00, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/4/2004 15:00:00, 3328 bytes
Device ID: PCI\VEN_10DE&DEV_0265&SUBSYS_72071462&REV_A1\3&267A616A&0&68
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0264&SUBSYS_72071462&REV_A2\3&267A616A&0&51
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0261&SUBSYS_00000000&REV_A2\3&267A616A&0&50
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/4/2004 15:00:00, 35840 bytes
Name: NVIDIA GeForce 6100
Device ID: PCI\VEN_10DE&DEV_0242&SUBSYS_72071462&REV_A2\3&267A616A&0&28
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.8133 (English), 9/18/2005 11:32:00, 3493984 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.8133 (English), 9/18/2005 11:32:00, 3905408 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.8133 (English), 9/18/2005 11:32:00, 131139 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.8133 (), 9/18/2005 11:32:00, 573440 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.8133 (), 9/18/2005 11:32:00, 46080 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.8133 (English), 9/18/2005 11:32:00, 5365760 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.8133 (English), 9/18/2005 11:32:00, 7204864 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.8133 (English), 9/18/2005 11:32:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.8133 (English), 9/18/2005 11:32:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.10540 (English), 9/18/2005 11:32:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.8133 (English), 9/18/2005 11:32:00, 229376 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 9/18/2005 11:32:00, 169499 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 9/18/2005 11:32:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0029 (English), 9/18/2005 11:32:00, 33280 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0029 (English), 9/18/2005 11:32:00, 33280 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
J_I_M_B_O said:I don't think so, my computer doesn't heat up in whilst in Oblivion. Although it does see logical...
And I know my computer heats up, but when I play oblivion and you but your hand in case, your can tell theres barely any warmthI've had the case open and a fan on whist playing and it made no difference
