VladDracule
- Feb 5, 2007
hey all,
so i was playing wow tonight then i take a brake to eat some dinner and come back a few hours later, my monitor went to power save mode, i wake it up and there is this awfull flickering. extremely noticiable, mess with my refresh rate reset factory settings etc. with no cigar.
first question is can you think of anything out of the ordinary i should try?
also, has anyone ever had to use NEC's warrenty specifically the advanced replacement option where they send you a new monitor then you send the deffective one back?
if so how well did it work out for you? the monitor is less than 5 months old problem just over 4, will the manufactor be more than likely to cover this problem?
also one last thing but im guessing ill have to ask nec about it, if i do the advanced replacement option send my monitor back then they say its a problem not covered by their warrenty what happens at that point?
thanks in advanced
thanks in advanced
