What clockspeed is your card idling at?
This.
Iddle clockspeed is one of the most common issues with the 5xxx and 6xxx, heck my original 6xxx made me go nuts until i did this:
http://www.techpowerup.com/forums/showthread.php?t=114562
post #2
BINGO, that's the problem. The HD5850 is supposed to idle at 400/1000157/300
<Feature name="CoreClockTarget_0">
<Property name="Want_0" value="40000" />
<Property name="Want_1" value="55000" />
<Property name="Want_2" value="72500" />
</Feature>
<Feature name="PowerControl_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="100000" />
<Property name="Want_1" value="100000" />
<Property name="Want_2" value="100000" />
</Feature>
<Feature name="CoreVoltageTarget_0">
<Property name="Want_0" value="1000" />
<Property name="Want_1" value="1038" />
<Property name="Want_2" value="1088" />
</Feature>
Use these values (the ones posted on TechPowerup are WAY wrong):
Code:<Feature name="CoreClockTarget_0"> <Property name="Want_0" value="40000" /> <Property name="Want_1" value="55000" /> <Property name="Want_2" value="72500" /> </Feature> <Feature name="PowerControl_0"> <Property name="Want" value="0" /> </Feature> <Feature name="MemoryClockTarget_0"> <Property name="Want_0" value="100000" /> <Property name="Want_1" value="100000" /> <Property name="Want_2" value="100000" /> </Feature> <Feature name="CoreVoltageTarget_0"> <Property name="Want_0" value="1000" /> <Property name="Want_1" value="1038" /> <Property name="Want_2" value="1088" /> </Feature>
Don't assign a 2d profile with Msi afterburner. Remove the 2d assignment reboot set it back to stock in CCC and just assign one to 3d that's all simple
Where/how do I do that? I'm using the new CCC which doesn't have menus, so I can't use the directions in the techpowerup postYou have to add a preset.
With the edited XML I get 400/900 that jumps to 400/1000 and now its flickering again....anything else I can do?
If 400 / 900 is your idle speed, apply the profile a second time, the memory speed will kick in.
If 400 / 900 is the result of playing hardware accelerated video, then you'll need to dump your video BIOS, edit it, and re-flash it to the card.
See bug #2 in The AMD Driver Bug Thread
