Fleshing out a Planned SB Build
PGHammer
I'm fleshing out a planned Sandy Bridge build, and because of falling prices and greater ease of installation, I've added water-cooling to the possibilities (specifically, the Corsair H70). Problem is, the radiator placement would not work with my current Lian-Li ATX mid-tower dating back to 2004.
That means a new case.
I have two CoolerMaster cases and two Antec cases on the short list.
The CoolerMasters are up first: HAF922M (mid-tower) and HAF932 (full-tower)
The Antecs are both from the Nine Hundred series - Nine Hundred Two and Nine Hundred SE.
Which would be best for an H70-cooled ASUS P8P67-based setup?
Doubtless a question that is going to pop up: Why would someone that has been singing the praises of Intel's push-pin mounting system for HSFs, namely me, be thinking about water-cooling?
Two reasons that dovetail rather nicely - falling cost for water-cooling setups and greater ease of installation.
Water-cooling setups used to be not only super-expensive, but were a bear to deal with. The advent of closed-loop packaged kits (including the H70) has knocked the bottom out of that. Even better, the H70 mounts *easier* than a lot of air-coolers.
