Tigerbiten
[H]ard|DCer of the Month - February 2007/January 2
- Sep 24, 2002
Got any pics of your farm? I am sure it has been posted in the past. Just curious what the #1 folding farm in the world looks like..
Grats on the achievement man! That is awesome!![]()
1x dual E5355's @3.4 Ghz.
I still love the fact you have a skulltrain setup.
That is badass! You have one hell of a system there Tiger.
It is still better then my Dual X5550 System cause you can overclock!
My farm is only 6 boxen strong now.
CPU's:-
5x i7 920's @3.9Ghz
All 6 are running bigadv for just over 24k PpD each.
GPU's:-
2x 9800GX2's, shaders @1728 Mhz.
3x 9800GTX's, shaders @ 1890 Mhz.
9x 9800GTX+'s, shaders @1944 Mhz.
All 13 GPU's are running the GPU client for around 4.8-6.8k PpD bepending on what card gets which protien.
But I'm thinking of adding another 9800GX2 back into the farm.
I should level out at around 210k PpD with a bit of luck.
That should put me around 20th in overall PpD ..........
So not a lot of hardware, but what I have is built to maximize my PpDpWatt.
At the moment I'm running at ~60 PpDpWatt.
That up from ~40 PpDpWatt from the last farm.
That was from before I upgraded to i7's and started to run bigadv.
But it's still well down from my max of 9 boxen running.
Luck .............
CPU's:-
5x i7 920's @3.9Ghz
GPU's:-
Luck .............
Also I'm building some i7 rigs. I think the Core i7 860 would give you a bigger ppd/w because from all the reviews it seems to consume at least 30 W less at load then a core i7 920. What do you think?
