FlashMenu with my IC7-G
e>X<stacy
It doesn't work properly for me. It gives me the following error message:
Any ideas? Thanks for any suggestions.
Okay. I just used the program and now after rebooting the computer the first time, it POSTs succesfully in 1.2ghz mode. I enter CMOS to set to defaults, rebooy, save changes and exit, and as soon as the POST screen comes up, it reads my CPU, the last line just shows that it recognizes the Hyper Threading being enabled, then it locks up. I can't enter into my BIOS. I've tried resetting the CMOS with no luck,meaning it doesn't reset. Where normally after resetting the PC would POST at 1.2ghz, it just keeps on trying 2.4ghz, as if it didn't reset. And I'm resetting the normal way, take the clip off and put it on the other 2 pins for 10 seconds then put it back, just like I used to do before. Any help?
