Flashing?
RandysWay
I heard you can flash the video card BIOS - never heard of this - I have a ATI (Built-by-ATI) 9700 Pro, where do I get the updated BIOS I can flash it with? Any performance benefits? I searched Google but came up dry.
Thanks, Randy
Essentially, you are flasing the bios like you would to a motherboard using the bios from another card manufacturer or card model. Sometimes this works, sometimes not. A safer option that probably wont hurt is to find the "sweet spot" for o/c'in your card ( as far as u can go and be stable ), then copy your bios,modify the speeds to your best, and re-flash it to your card. The card will now ALWAYS run at these speeds, instead of having to load a software program at start-up to o/c the card.:cool:
Oh, I see. So theres no updated BIOS for the specific card from ATI, like a regular motherboard BIOS. Thanks..=)
No. All I've seen is downloadable bios' from current cards-people who like to mess around. If I was going to try, I'd probably do it on my older/backup card in case something goes wrong.......not my best card, untill I've become familiar with the process. I understand though, that as long as you keep an un-altered copy of the origonal bios, if something craps out, you can flash it back to norm. In all this you will also need to have a pci video card in case the flash is bad( install pci card so you can see the screen.......go through the flash process again, putting the origonal bios BACK on the agp card.......remove pci, and make the agp primary again........repeat if you are brave enough to try again).
