Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
u can bios flash the x850pro *note(AGP versions are best at this bios flash)to xt with 16pipelines but keeping the default core and mem settings cause of stock cooler, if u want u can get a zalman 700 vga cooler and add that and up the core/mem to xt speeds
Here's what I did:
Downloaded ATIflash 3.09 and saved the EXE to the hard drive
Downloaded X850 XT BIOS (AGP, non Platinum) and renamed that long filename to "xt.bin"
Uninstalled all ATI software
Boot disk to DOS and run ATIflash
BACKUP OLD BIOS:
atiflash -s 0 oldbios.bin
FLASH TO NEW BIOS AND OVERWRITE ALL SETTINGS:
atiflash -p 0 xt.bin -f -newbios
FLASH TO OLD BIOS AND RETAIN PIPELINES:
atiflash -p 0 oldbios.bin -f
Reboot, install Catalyst drivers
Check pipelines using ATITool
Just in case, I'll repeat that my card is the AGP version. Good luck.
all you have to do is flash your old bios back onto the card with atiflash
atiflash -f -p 0 oldbios.bin
this should flash ur old bios back but leave the 16 pipes in the rom settings.
and watch temps if u decide to use AtiTool to find Max core/mem settings and it will scan for artifacts also, very good program i always leave it open in tray to monitor temps.
do u already have the bootdisk? www.bootdisk.com will need one for newer OS's like XP etc...
i have the tools forgot where it was i got them, im gonna see if i can host the files somewhere. or if u have Aim messenger i can send, or email address?
