Flashing Underscore at boot won't go away
—§urfÅceЗ
I reset my CMOS with the jumper earlier today, and my computer worked again. I went into BIOS to set the time and boot priorities, setting the CD drive to top priority since I'll be installing Windows.
So I said exit and save, my computer restarted, and now I just get a blank screen with a flashing white underscore in the top left corner. It doesn't go anywhere from here.
Did I probably mess something up in the BIOS? Should I hit the jumper again?
Well I just tried to reset the CMOS again, and now I know what has happened. This is my first build, so I probably forgot to set something in the BIOS.
So I reset the CMOS, and turned on my computer. I get a nice Ai Proactive screen from ASUS, so I know things are kind-of working. I then enter the BIOS, set the time/date and boot priority (with CD drive at top priority in order to install Windows). I then say exit and save BIOS.
So my computere restarts and I get the Ai Poractive screen again. This time, it tells me to press Delete to begin Setup. What setup? So I press Delete and it says "Entering Setup" or something like that for the longest time. I didn't think it was doing anything (maybe it froze?). So i reset the computer and thats how I get the flashing underscore.
Perhaps I forgot to set something in the BIOS. Or do I need the ASUS drivers CD? I never got that.
Sort of. The HDD has a Windows XP on it, but it has been corrupted. So I either have the repair it with the CD or reinstall it with the CD.
I can get a completely fresh start by resetting the CMOS with the jumper, which I've done a few times now. I can then enter the BIOS and change things. Something I have changed each time is setting the top priority boot device to my CD-RW drive so that the Windows CD will run. After exiting and saving the BIOS, the pc restarts, and gives me the ASUS Proactive Ai screen, and at the bottom it tells me to press DEL (delete) to begin setup. I do so, and it says "Entering Setup" forever. If I turn off the pc while it says this, when I restart, I get that flashing underscore until i reset the CMOS again.
As I said, this is my first build. I must be forgetting something. I dont have the drivers CD for my MoBo because I didn't think I needed them.
Ok I think this is turning into a motherboard issue. I did notice that when I look in the BIOS, it says that the CPU is an unknown AMD Hammer family processor. It doesn't recognize that it has two cores, and says it's clocked at like 5000mhz, which it is certainly not. Each core is at about 2.6ghz.
I'm thinking I need to get a newer version of the BIOS that supports my CPU.
Funny how it isnt able to identify it....
