Flashing problems...
uB3rn00b3r
I have a dfi nb71-bc mother board. I want to overclock my p4 2.4b but I cannot find temperature readings in the bios. I decided to flash my bios to the newest version and see if they show up. When I try to flash the bios it says that I have entered a bad command. I am using
A:\>[executable] [filename].bin /F
with the appropriate things filled in.
Any suggestions?
Also is it possible that a motherboard does not have something to read temperatures?
Thanks.
If you want to read your system temps, try the programs Motherboard Monitor or Speedfan.
