Flashing Mobo help
riptid3
I'm going to flash my KT3-Ultra2, and need to boot up in dos mode on a legit version of Windows XP home edition. Is there a way to do do this WITHOUT a working floppy drive? Mine has been broken fo-evar, but I haven't needed it 'till now.
Check your MoBo manual, that one may have the "Live-BIOS"
MSI’s Live Update 2 software is a welcome inclusion in their software package. Live Update 2 allows you to update your BIOS, Drivers, VGA BIOS, VGA Drivers, and Utilities through an internet-based environment. When you open the program, it will open your web browser to a window as seen above, and lets you select which application you wish to run. In the image, I clicked on “Live BIOS” to show you the screen that one would see if they were to do so. With this, it will download and install the latest BIOS for you motherboard through Windows. I’m not much of a fan of updating the BIOS through Windows; however I’m becoming a little fonder of the idea with experiance. The Live Update 2 software also comes along with a program that runs in the taskbar entitled “Live Monitor.” You can set this program to randomly check for new Drivers, BIOS’, etc. at a given amount of time. This way you don’t have to check for new files yourself, you just wait for the Live Monitor to inform you that there are new drivers, and proceed to launch Live Update 2 and install the new set. It’s as easy as that.
Sweet, Thanks CaptainDomo, that took care of it. Now I can up the Clock Ratio :D
There must be a lesson in here somewhere....be helpful and you get demoted in rank :p
