It will do both cards at the same time, gpu1 first, then gpu2. It will prompt you before flashing each one though, so you can stop the process once it's flashed the 1st card if you want. It's very easy. did it two days ago.. make sure you get the latest version of NVflash if you are going to flash 7900 series cards..
