flashing bios then clearing cmos??
mooooooon
Ops, I think I mess up my Supermicro X5DA8 motherboard, I like had a 1.2b bios number and I update the bios to 1.3b and it will want to read some of my RAM like 2.5 gigs one day and the next day it will read the full amount like 3.5 gigs and down to 1.5 gigs.
I flash the same bios number 1.3b several times and it would mention a successful update and would boot in to window xp. I check in the control panel systems and it would display the correct amount of RAM, but if I turn it off and on I end up getting a text display of "bad cmos sum check error"
The manual told me to use a screwdriver and touch these two silver dots next to a printed text on the motherboard saying "clear cmos" and I did that it didn't seem to fix anything other then defaulting the bios setting.
At first I though I had a weak EPSV12 550watt power supply trying to power two 3.2 cpus, 9 fans, 4 hard drives, two video cards, two tv tuners, a cheap sound card, 4 sticks of RAM and a dvd dual layer drive that it couldn't power the rest of the system and disable them.
The weirdest time that I found out if I put all 6 stick of RAM the system it won't turn on, and if I go to unplug the power to remover the extra RAM the motherboard would give me a light show, like it would make a loud beeping noise with the fan spinning and glow a bright red light from the LAN NIC lights for about two seconds before the power is totally off, no lie I am shock that it still works, but it's gimping my e-penis :(
hey, i fix my problem. it seems that if i set the video card memory size to 64 from 256 in the setup in the cmos, windows xp can read the full amount of RAM. but does this affect the games that i play?
does anybody knows why that it happens. :confused:
help!!! now i am trying to run three monitors. am i suppose to set the primary to pci in the cmos? for some reason in the windows xp display properties i see four boxes labled 1, 2, 3, 4. right now i am using box 1 and 2.
box one is set at 1920X1200 and box two is set at 1280X1024. and i like to use the radeon 9250 pci card at 1280X1024, and every time i try to enbale the moniots 3 or 4 the system stalls and reboots it's self?? iam using a fire gl x2 for my main video.
omg it works now,
just installed a better psu, pci card,
ENERMAX EG851AX-VH(W) FM EPS12V 660W Power Supply 90
SAPPHIRE RADEON 7000 64M DDR PCI
then change the settings in my x5da8 bios to used 64mb RAM, APG to primary.
i did not install the drivers that came with the pci card, windows xp installed it without it.
yea me, rawr
